An exception occured EditExtension Error
Discussion in '3CX Phone System - General' started by stevef, Nov 17, 2016.
  1. stevef
    Jul 20, 2007
    38
    I can no longer make any changes to configurations within the 3CX console (v12.5)
    The phone system seems to be working fine but when I try to make a configuration change I get a 3CX Interface exception error. When I try to make a config change to an extensions settings I get the following error.
    'An exception occured EditExtension Error: Exception has been thrown by the target of an invocation InnerException: FwdProfile'
    I get a similar issue if I try to edit the rules for an inbound DDI. 'An exception occurred InboundRules Error: ExternalLine'
    It seems I just can't make any configuration changes, although everything currently appears to be working OK, I just need to change some stuff.
    Any ideas what is happening?
    I am getting multiple PostgreSQL errors in the application event logs.
    ERROR: could not open file "base/16385/18973": Invalid argument
    STATEMENT: select*from calendar where idcalendar=2
