An exception occurred EditExtension Error
Discussion in '3CX Phone System - General' started by brianoakes, Feb 25, 2015.
  1. brianoakes
    May 12, 2012
    92
    Howdy!
    I am getting the following error when saving an extension when I am editing anything in the extension.
    An exception occurred EditExtension Error: Server execution failed.
    I have added/remove BLF's or change the email address. Same issue. Once I press ok to clear the message the dialog closes, and my settings appear to be changed. When open the extension again, the settings appear to take effect.
    12.0.37098.738 SP.6.1
    I have also seen a similar error: An exception occurened MailForm Error: server execution failed.
    any ideas? I have seen this for a while. I did a uninstall/re-install and restore of the data, and the problem was still there.
    Thanks!
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Locking this topic as support ticket investigation leaded to your hard drive hardware health. After correcting, reinstalling/restoring it worked.
