Analog Audio Source
Discussion in '3CX Phone System - General' started by skeeloson, Mar 10, 2014.
  1. skeeloson
    Mar 10, 2014
    We have a series of analog audio devices that we would like to give phones extensions to. What type of device could accomplish this. The audio devices would be the equivalent of a radio scanner.
    Would it then be possible to have the extension auto-answer when someone dials it? These extensions would be used for troubleshooting purposes. If someone calls in and says a particular radio channel is garbled, the tech could dial the extension that corresponds with the audio and listen.
    Thank you in advance for any help.
    Scott Klein
  2. fred_gallon
    Nov 28, 2013
    7
    First tought (rather expensive I must admit) Use a Mobotix cam and connect your audio device to the mic input. Auto accept VOIP calls is possible with them.
