Analog IP Gateway's - Reccommendaey tion
Discussion in '3CX Phone System - General' started by mattstarkie, Jul 12, 2009.
  1. mattstarkie
    Feb 22, 2008
    Hello
    I am currently using 3CX small business edition and i am looking to link our system up to the POTS.
    We currently have 2 lines but will be extending this to 4 in the near future.
    We are using Grandstream phones.
    I have used the grandstream 4 port gateway a few times on this system and have had nothing but problems with it. So i was considering buying a completely different model.
    So if anybody can reccommend one they are using and have found reliable and overall good then it would be much appreciated.
    Thanks,
    Matt Starkie
  2. sipero123
    Nov 24, 2008
    94
    I would suggest a patton gateway.
    Jonathan Hamon
  3. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    +1 for Patton - you would need a SN4114
  4. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    patton too. 4112 or 4114 like said discovery.
  5. voipbaennjer
    Jul 10, 2009
    44
    I had problems with Grandstream GXW-4104 POTS Gateway delivering phantom calls. Phone rang but nobody was on. I returned it 'cause I didn't know weather it was broken or it was the way it was (newest firmware was installed). Now I'm using Fritzbox 7170 'cause it works without problems and it delivers the caller id faster and 100% error free. The 4104 took some ring cycles until the phone rang and then it did not allways present the caller id...
