Analog Phone Call Transfer
Discussion in '3CX Phone System - General' started by sgiddey, Nov 30, 2011.
  1. sgiddey
    Aug 26, 2009
    14
    I have a Linksys SPA 3102 for my POTS line. This is handy as I can have an emergency line in case of internet down or power failures... However, I cant seem to figure out how to do a call transfer from the Analog phones that I have I am using a Linksys ATA 2 port. Any ideas would be most welcome tried *78 etc to no avail
    Thanks in advance
    11,116
    329
    I'm not sure what the 3102 has to do with an internal call transfer, so I may not be understanding your problem.
    Most attended transfers in 3CX, using an ATA, are done with ,flash, ,get dialtone,dial extension number, wait for party to answer, announce the call, hang up.
    Unattended (Blind transfer), involves, flash, get dialtone, dial blind transfer code (this can differ, or be set, depending on the make of ATA), get dialtone again, dial extension number, hangup.
    I have to assume that you are dealing with transfer between 3CX extensions and not an analogue set, on the 3102 (FXS port) directly answering the PSTN line (not set-up as a 3CX extension).
  3. sgiddey
    Aug 26, 2009
    14
    Leejor
    Thanks again.. Flash works well for the transfer.. All the documentation I was reading stated ## ext. This was not working but now I am good. Appreciate the help this forum is fantastic
