Analog phones on the 3CX system
Discussion in '3CX Phone System - General' started by pdq, Dec 29, 2014.
  1. pdq
    pdq
    Dec 3, 2009
    82
    I have analog extensions connected to the 3CX system via Linksys adapter.
    Having issues transferring from analog extensions to the digital desk phones.
    Anyone have suggestions/experience? :?:
    11,126
    330
    You'll have to provide additional information about the type of transfer (attended , or unattended), and what the "issue" actually is. A hook-flash, attended transfer, is pretty straight forward, and does not usually cause problems,
  3. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Indeed, I use the hook-flash transfer with the analog Polycom units on an SPA3102. Seems to work okay for blind transfers, attended transfers, and conferences.
    You will need to configure those options in the SPA3102 UI.. I don't think a template gave me those types of options I needed.. and the codes were of my own choosing anyway.
