Analog Phones
Discussion in '3CX Phone System - General' started by cdanik, Dec 25, 2007.
  1. cdanik
    Dec 25, 2007
    Is there any way to use standard analog phones instead of USB phones? Can the phones be hooked up to a modem in the computer?
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    You can use devices such has Linksys PAP2 to do that job, it will allow you to connect "normal" phones to a voip provider or in this case to 3cx, you will be abble to connect 1 or more phones depending on the model you choose, you have several brands selling this kind of devices....
    Search for ATA adaptor Voip on google and you will get alot of results.
    Cheers
  3. cdanik
    Dec 25, 2007
    I have 1 line right now. I have a vonage adapter that is connecting all my phones to the VOIP Provider (Vonage). But how do I assign those phones an extension?
  4. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Well, to assign several phones has extensions you need 1 adapter per phone or 1 adapter for 2 phones(depending on models) and then you set server, or proxy, or both with 3cx server ip, Id and pass like you have set on 3cx. This are the basics....
    Cheers
    More help can be provided but we need to know what device and model you're using, or intend to use...
  5. cdanik
    Dec 25, 2007
    What is the cheapest model out there? Do you know?
  6. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Well, i dont know if it is the cheapest, but its the one i use at home, and it works very well, i have a Linksys PAP2. Works without any issue at all, has 2 ports to connect 2 normal phones and 1 ethernet to connect to the server(3cx or a voip provider). It costs about 45Euros or... around 60Dollars...
    Cheers
  7. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    I use several Grandstream HT386 that give you the facitilty to connect 2 analog standard phones to each fxs port (2 port every ht386 adapter)
    fantastic voice quality... no echo.
