analog telephone adapter
Discussion in '3CX Phone System - General' started by jmatson, Dec 13, 2009.
  1. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    I am looking for a good analog telephone adapter. SO i can use my normal analog phone with my 3cx. I find some on ebay. but not sure what is a good one to get.
  2. abundisnet
    Sep 23, 2009
    18
    I had tested Linksys PAP2 and Grandstream HandyTone
    Both work great
    voiptoys likes this.
  3. turnkey
    May 9, 2009
    64
    I've been recomended the Patton SmartNode 4112 Analog PSTN Telephony Gateway.
    http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=7695
  4. leejor
    11,077
    324
    Personally, I like the Linksys SPA3102 if you want both an FXO and FXS port, or the SPA2102 for two FXS ports. Lots of features which means that they can be a bit overwhelming for someone just getting into VoIP. They aren't the least expensive ones out there but they are very flexible and I've found them to be very reliable.
  5. btb128
    Nov 12, 2009
    8
    I recently purchased a Patton ATA adapter from Deerfield.net It is really small. I tried it out with a normal phone and it worked nicely, we use it for our fax machine and it has worked great. It was really easy to setup.
    http://www.deerfield.net/p-58-patton-m-ata.aspx
