Analogue Call Transfer keys.
Discussion in '3CX Phone System - General' started by wzaatar, Dec 14, 2008.
  1. wzaatar
    Aug 1, 2007
    90
    Hello, community!
    I am trying to locate the keystroke sequence to use when blind transferring calls from one extension to the other for analogue phones (VoIP phones have a TRANSFER button).
    Did anyone come across this?
    Thanks,
    W.
