Analogue Line VOIP Calls
Discussion in '3CX Phone System - General' started by Ahmad, Aug 16, 2008.
  1. Ahmad
    Aug 16, 2008
    I do travel a lot and while traveling I want to call using my home analogue line. The Idea is to connect to a device in home network using internet from another country, and this device should enable me to use my home analogue line to make phone calls.
    I did some research and my finding is to use SIP Server (3CX) and FXO Gateway.
    Is that right ? if yes which hardware do you recommend ? I’m asking because I don’t want to buy stuff and end up finding that they don’t work.
    Sorry for my bad technical explanation, I’m IT specialist but I have limited knowledge of VOIP.
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Ahmad
    analog fxo device 1 port
    Linksys spa3102
    Grandstream HT503
  3. Ahmad
    Aug 16, 2008
    Thank you amygoda, I will try the recommended hardware.
  4. radelman
    Feb 21, 2008
    60
    I am using Grandstream 2010 sip phones along with a Grandstream 4104 fxo gateway with 4 pstn lines attached for about 6 months. NO problems with egress or access so far.
