Andriod app 3CX. Please help
Discussion in 'Android' started by funnykiller, Sep 1, 2010.
  1. funnykiller
    Sep 1, 2010
    I downloaded the andriod app 3CX and for some odd reason it will not register.
    At the profile area all it does is say "waiting for profile please be wait" and it
    Never creates one. I know I kan set it up manually so I googled it and gave me
    Instructions but there to technical for me to understand. Kan some one give it
    To me in "dummy" terms? Pleases and thanks!
