Andriod Ringtones
Discussion in 'Android' started by KevT, Mar 19, 2014.
  1. KevT
    Mar 19, 2014
    How do you change ringtone in v12
    Samsung Galaxy s4
  2. bobdigby
    Feb 20, 2014
    19
    I don't think you can. This feature is really needed though. Come on 3CX this must be easy to add.
  3. schumm
    May 3, 2014
    I dont have a ringtone at all on my samsung tablet.
  4. 3CXNP
    3CXNP Support Team
    3CX Support
    Apr 25, 2014
    44
    Hi Guys,
    Ringtones are not available on 3CXPhone yet. They will be available in an upcoming version where you can choose a ringtone from your phone.
    The Android version will be the forst version to have this new feature, followed shortly by other platforms.
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    glad to hear it.
  6. MariosS_3CX
    May 26, 2014
    12
    The latest version of the 3CX Phone for Android supports changing the ringtone, this can be done by navigating to Settings > Advanced > Select the "Use System Ringtone" and select a ringtone by pressing the Ringtone option.
