Android 15.1.41
Discussion in 'Android' started by Mani-cal4care, Aug 19, 2017.
  1. Mani-cal4care
    Aug 17, 2017
    I’m sharing an problem encountered today. The 3CX soft client isn’t stable. Observed two peculiar behaviors:
    1. Current call disconnects if a secondary call lands.
    2. Call controls are not available on screen when a call is picked up.
    3. call also, on its own, goes to speakerphone, post pick up
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,486
    357
    Hello @Mani-cal4care
    Are you experiencing this if a GSM call arrives or a second call to the client?
    Can you explain the scenario and send a screenshot so we can understand the issue?
    when you pick a call up and place it on you ear does the screen go black? I would assume the speaker button is pressed accidentally while you are on the phone.
    What device(brand, model) are you using?
  3. Mani-cal4care
    Aug 17, 2017
    Its a direct calls to the client .
    No
    Phone is "Coolpad Note 5" and OS is Android 6.x.
    please use the link to download the incidence https://www.dropbox.com/s/qfhwp0s8d425typ/Screenrecord_2017-08-19-15-58-30.mp4?dl=0
  4. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    245
    12
    Hello @Mani-cal4care,
    - On the Video I cannot see any problem comes from the 3CXClient. Run a wireshark capture on your PBX server and see what is actually happening.
    - Regarding secondary call, can you also make a short video as I am not able to understand the issue here? Also, make sure that you have enabled "Accept multiple calls" for the specific extension.
    - For the 3rd issue, regarding call goes to speakerphone, do you have any Bluetooth device connected on your phone?
    Thank you
