Android 3CX Client - prevent status bar interruptions and phone locking on active call
Discussion in 'Ideas' started by Brad Allison, Mar 28, 2018.
  1. Brad Allison
    Jun 7, 2017
    63
    15
    I usually end up using the Android 3CX client on speakerphone as when i try to use the phone up to my face the status bar keeps popping open and close as a result other things eventually happen, like disabling my wifi, turning on my flashlight on, opening up notifications over top of my 3cx app.
    At times my phone will lock during an active call, when i try to end a call I have to unlock my phone before i can actually end the call.
    I do not have this problem with other UC apps.
    This is my 3rd android phone that has done this, no matter the Android OS version or 3CX app version.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,037
    119
    Hi Pls Check that Proximity sensor in Settings is on. Then it should not give you problems.
