Android app rings while already in phonecall
Discussion in '3CX Phone System - General' started by Peter Richardson, Jun 19, 2017.
  1. Peter Richardson
    Peter Richardson New Member
    Apr 6, 2017
    230
    9
    Hi all,
    I'm using a HTC One M9, latest version of Android, latest version of the app. When I am on another call (normal phone call), it's still possible for the 3CX to ring, and if I answer it, I end up talking to both people at the same time (but they can't hear each other). What's the solution to this?
    11,073
    323
    Did you have a look through the 3CX Android Forum? There are a number of posts regarding the "interaction" of the 3CX client and incoming mobile calls. Updates have been released to deal with some problems, but I don't recall your specific issue happening before.
  3. Peter Richardson
    Apr 6, 2017
    230
    9
    I'll have a look.
    I can't possibly roll this out to my clients as is. Has anyone else had this issue?
