Solved Android - Call Queue Agents
Discussion in '3CX Clients' started by geedee, Nov 13, 2017.
  1. geedee
    May 5, 2011
    16
    Hi all
    I am hoping that someone could advise on correct process.
    In my 'Call Queues' I have my Android extension displayeds as part of one of the agents for said Call Queue.
    I have to be missing something as the device refuses to ring on inbound call queues from digital receptionist.
    I can make calls and can receive direct dial calls from office on 4G or wifi.
    Assistance greatly appreciated.
    Thank you
    Sean
      File size:
      88.9 KB
      9
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,380
    535
    Is the extension logged in to the Queues? Does it appear as registered in the extensions Tab? Navigate to the extension tab select the extension and click on Status. Does it appear as logged in?
  3. geedee
    May 5, 2011
    16
    Thank you Yiannish!
    I could not find that at all... All sorted.
    Cheers Yiannish
  4. YiannisH_3CX
    May 10, 2016
    7,380
    535
    Glad the issue is resolved
