Android Call Security
Discussion in 'Ideas' started by sswbn, May 24, 2016.
  1. sswbn
    May 24, 2016
    With v14 it is only possible to make or receive calls on Android by using Google, which is insecure, since call information would be collected by Google.
    Please introduce encryption, so that the phone numbers and the calls themselves cannot be accessed by unauthorised parties. We cannot currently advocate 3CX's use in a corporate environment, or indeed in any environment where security is important.
  2. uptime1
    uptime1 New Member
    Jan 13, 2012
    112
    30
