Android client cannot change DND or Queue Status
Discussion in 'Android' started by ccexpert, Apr 28, 2014.
  1. ccexpert
    Apr 9, 2014
    18
    Using the 3CX cloud version and the Andoird client as a remote phone. The Android client cannot log in our out of the queue nor can it enable or disable DND. Will this work when the phone is remote from the server?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    304
    Atleast on my iphone I can change status remotely. But I am not on cloud version.
    On your device can you see presence?
    I know at one time, I had trouble seeing presence and setting status remotely but restarting 3cx fixed that for me.
  3. ccexpert
    Apr 9, 2014
    18
    Service Pack 5 cleared this up for me.
