android client for TLS connection?
Discussion in 'Android' started by ddywz, Aug 18, 2013.
  1. ddywz
    Aug 16, 2013
    6
    I setup the 3CX phone system with TLS and enabled the ceritificate for SIP. Also switched to port UDP 5061. How to I switch android client to connect TLS? I did change the PBX port to 5061 but I don't think it s running on secure mode. Where should I put the certificate on the phone? Does android client version 12 currently support TLS? If so is there a doc on how to do so?
    Thanks,
  2. AndreasA_3cx
    AndreasA_3cx Guest
    Hello there and thank you for contacting us.
    Unfortunately TLS is not supported for Android devices.
    Kind Regards
