Solved Android client stopped working with the new update.
Discussion in 'Android' started by 9009, Feb 26, 2018.
    Jun 19, 2016
    32
    The Android client was working, but after the last 3cx 15.5... update it stopped working. It shows registering and then Register Failed.
    I uninstalled the client, deleted my Firebase project and created a new one, updated my 3cx machine with the new Firebase info, sent a new welcome email and processed it.
    The client is still not registering.
  2. Brian Suing
    Dec 16, 2016
    9
    Does the server immediately ban the IP of the android? Clear out some newely blacklisted IP's
    If it blacklists again, then we are in the same boat.
  3. 9009
    Jun 19, 2016
    32
    It started working on its own. I checked, the IP was not Blacklisted when it was not working. It didn't work for 2 days and somehow started working again.
