Android Galaxy Spica 2.1 FM
Discussion in 'Android' started by compufirm, Jul 28, 2010.
  1. compufirm
    Jan 4, 2010
    6
    Hi Everyone
    I have never actually been able to get this 3cx phone to deliver audio when using 3g, I can get it to work on Wireless connection, but not 3g.
    It registers and it receives calls, I can answer them, but neither end hears anything.
    Also, when I click "Available" (I am assuming it should let me change my status) it does nothing. Any ideas :?:
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Depending on your carrier, it may or may not work over 3G. Test it over a remote wifi connection to make sure its not a NAT or firewall issue. If a remote wifi connection works and the 3G connection doesnt there may not be anything you can do about it until the 3CX tunnel is added to the Android phone.
