Android Push
Discussion in '3CX Phone System - General' started by donbru01, Nov 30, 2014.
  1. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Hi at all ,
    How can verify if my android phone is registered on GCM project?
    I have setup all corretcly ( i suppose ::)) , voice , chat via tunnel work fine .
    But when 3cxphone for android go on sleep mode , no push notification i receive for wake-up
    Thanx
    10,758
    286
    I'm not sure what sort of "sleep" that you phone goes into, and you don't mention what model it is. On my Samsung, even after the screen goes dark, it is set to maintain a wifi (or 3/4G) connection, and will ring if there is an incoming call. I don't think that "push" is involved as unlike the iPhone, it remains registered in the background even if you are using another app. If you are having issues it may be a network setting , on the phone that has to be changed.
    By the way, there is a forum just for android issues....
  3. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Thanx Leejor , i must use push for better battery saving , for special project .
    3CX V12 implement push , i suppose 3CX believes in this future .
    I try to use Samsumg S3 mini and Tablet and same issue no push for wake-up .
    I have trace via wireshark 3CX System when from device i call another device provisioned for push , but from 3cx i not see request for https://android.googleapis.com/gcm/send.....
    But my skill for this scenario isn't good .
    Thanx
