Android soft phone stuck
Discussion in '3CX Phone System - General' started by Peter Richardson, Dec 21, 2017.
  1. Peter Richardson
    Peter Richardson New Member
    Apr 6, 2017
    198
    8
    Hi all,
    Please see attached screenshot. Stuck on this screen, won't connect. Am running all latest software updates on phone and PBX. Any ideas?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @Peter Richardson
    It looks like the client cannot connect to the PBX. Make sure that your port forwarding is correct and the firewall checker successfully passes. Also make sure that under extension settings / Phone provisioning / 3Cx client the option "Use 3CX Tunnel for remote connections (3CX Client only)" is enabled. Do you have the same issue in the local WiFi?
  3. Peter Richardson
    Apr 6, 2017
    198
    8
    Thanks @YiannisH_3CX
    Port forwarding is correct
    Firewall checker passes okay (nothing has changed here, just new updated client)
    "Use 3CX Tunnel for remote connections" was already enabled.
    No, this issue does not happen when connected to WiFi at home, but I do have a VPN tunnel going to the PBX site, so that might not give you the answer you were looking for exactly.
    Phone app version is 15.5.196
    PS, when I try to click on anything in the app, it just freezes. I have to close it and reopen it once I have wifi connected.
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,473
    94
    Please upgrade to 201, it's fixed in the latest beta.
  5. Peter Richardson
    Apr 6, 2017
    198
    8
    Thanks @LeonidasG
    How do I upgrade? It does not give me an option to upgrade in Google Play Store, and I can't seem to find an upgrade option in the app itself.
    Thanks in advance for your help!
  6. LeonidasG
    Nov 19, 2008
    1,473
    94
  7. Peter Richardson
    Apr 6, 2017
    198
    8
    Thanks @LeonidasG but when I click that link from my phone I get this error message (see attached)
  8. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    You can click on that link from anywhere. It simply joins you to the beta program. Open your browser and type in the address if your links are screwed up.
  9. Peter Richardson
    Apr 6, 2017
    198
    8
    Thanks @jimbo59 indeed you were correct, the link was screwed up. The old copy and paste worked a treat!
    I registered and installed the update and now it connects SO FAST. it used to take about 15 - 20 seconds before, now it only takes 2-3 seconds. Great work guys!!
    YiannisH_3CX likes this.
  10. Boyin
    Jan 21, 2018
    I followed the suggestion to use the beta version because I was experiencing not connecting and freezing/delay after tapping on answer when a call comes in.
    Connectivity has been great but now the 3cx app is draining significant amount of battery, 2% overall before, up to 23% overall on the beta.
    Anyone experiencing this? Is there anything settings I need to turn off? Verbose logging is already off.
