Animated Status Bar icon Windows Softphone
Discussion in 'Ideas' started by DL_, Nov 25, 2017.
  1. DL_
    DL_
    Mar 31, 2015
    55
    8
    I see there is another idea active to have a different colour icon in the status bar depending on your presence. I would also like if it was animated or blinked if there was a missed call or voicemail since you last opened the softphone.
