Aniother issue with VAD current
Discussion in 'CRM / Helpdesk / App Integration' started by millsey, Nov 7, 2012.
  1. millsey
    millsey New Member
    Dec 21, 2011
    203
    If we drag a user defined component into a flow, there appears to be a tag missing off the xml.
    This is the XML of a part of a flow which simply "goes" to another component:
    <vxml version="2.0" application="Root_Fletchers.vxml">
    <catch event="error.semantic">
    <assign name="project$_CurrentErrorName$" expr="_event" />
    <assign name="project$_CurrentErrorDescription$" expr="(_message == undefined ? '' : _message)" />
    <goto next="FS_ErrorHandler.vxml" />
    </catch>
    <error>
    </error>
    <catch event="connection.disconnect telephone.disconnect">
    <goto next="FS_DisconnectHandler.vxml" />
    </catch>
    <form>
    <block>
    <var name="application.SelfServeRef_loopcounter" expr="0" />
    <var name="application.FS_goselfserveroneone_loopcounter" expr="0" />
    <var name="application.SelfServeRef_extension" expr="0" />
    <var name="application.FS_goselfserveroneone_extension" expr="0" />
    <var name="application.SelfServeRef_clientname" expr="'NONAME'" />
    <var name="application.FS_goselfserveroneone_clientname" expr="'NONAME'" />
    <var name="application.SelfServeRef_casenumber" expr="0" />
    <var name="application.FS_goselfserveroneone_casenumber" expr="0" />
    <var name="application.SelfServeRef_casenumbervalid" expr="0" />
    <var name="application.FS_goselfserveroneone_casenumbervalid" expr="0" />
    <var name="application.SelfServeRef_fee_email" expr="'brianmills@fs.co.uk'" />
    <var name="application.FS_goselfserveroneone_fee_email" expr="'brianmills@fs.co.uk'" />
    <var name="application.SelfServeRef_realcasenumber" expr="0" />
    <var name="application.FS_goselfserveroneone_realcasenumber" expr="0" />
    <var name="application.SelfServeRef_NextComponentUri$" expr="'FS_MF_goselfserveroneone_Suffix.vxml'" />
    <var name="application.SelfServeRef_NextErrorHandlerUri$" expr="'FS_ErrorHandler.vxml'" />
    <var name="application.SelfServeRef_NextDisconnectHandlerUri$" expr="'FS_DisconnectHandler.vxml'" />
    <goto next="SelfServeRef.vxml" />
    </block>
    </form>
    </vxml>
    There is missing fromt he top of this file a definition:
    <?xml version="1.0" encoding="UTF-8"?>
    This is a _Prefix.vxml file, The Suffix is also missing this tag. The call flow vxml iteself DOES have the tag.
    By adding this in, the flow works properly. I only discovered this because other xml files which make up the flow always have this header.
    We are using version 3.0.3839.0 VAD
    Millsey
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi Millsey,
    Yes, we already noticied this and have made the fix, which will be available in the next release.
    Thanks for reporting it anyway.
    Kind regards,
