Anonymous Call Blacklist
Discussion in '3CX Phone System - General' started by mukkacow, Nov 14, 2017.
  1. mukkacow
    Oct 26, 2017
    46
    6
    I have a problem for blacklisting some anonymous calls. One of my providers handle anonymous call like this:
    I have set *non* in "Blacklisted numbers" but this seems work only for providers that handle anonymous calls like this:
    Are there any solutions to solve this problem ?
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    Add Anonymous, anonymous, Unavailable and unavailable, one per line, into blacklist for numbers.
  3. mukkacow
    Oct 26, 2017
    46
    6
    Hi @ship.bg,
    It doesn't work. It only works if after sip: you have something (eg. sip:Anonymous@xx.xx.xx.xx). In this case the provider if call is anonymous does't write anything after sip: and the result is that blacklist will not work.
  4. sip.bg
    Nov 7, 2016
    704
    220
    Providers usually send 'Anonymous' or 'Unavailable', not an empty string. If string is empty, you don't have criteria to block call.
    Analyse your traffic.
  5. mukkacow
    Oct 26, 2017
    46
    6
    When you have a situation like this and you have for eg. anonymous after sip: then you can block it using the "Blacklisted numbers".
    In my case the provider when calls are anonymous doesn't write anything after sip: so there is no way to block it using "Blacklisted numbers".
    In this case noway to block them ?
  6. sip.bg
    Nov 7, 2016
    704
    220
    I'm afraid, not.
  7. mukkacow
    Oct 26, 2017
    46
    6
    Thanks you. Will try contact the provider.
