Anonymous CallerID will not forward to outside line
Discussion in '3CX Phone System - General' started by wblake, Jan 19, 2010.
  1. wblake
    Jan 10, 2010
    Our system uses the 3CX with both SNOM and Polycom phones and PINS VoIP service and an outside line answering service.
    Incoming calls with anonymous caller ID do not forward to outside lines, while incoming calls having caller id forward to outside lines. Our system seems setup to block outgoing Caller ID. Does this need to change?
    When customers call with anonymous caller ID, their calls will not forward to an outside line with this message in the log
    08:40:11.546 [CM303006]: There's no outbound rule for external number '5617033677' defined
    However when calls arrive having Caller ID , call forwarding to an outside line proceeds normally. I enclosed the Server Log listings for the calls with anonymous Caller ID and with valid Caller ID.
    Thank you,
    Wil Blake
    Anonymous CallerID Call
    08:40:17.578 [CM503008]: Call(7): Call is terminated
    08:40:11.781 [CM503003]: Call(7): Call to sip:895@63.224.85.165:5070 has failed; Cause: 487 Request Terminated; from IP:76.109.102.155:5070
    08:40:11.734 [CM503007]: Call(7): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=f32573dec7eacca0
    08:40:11.734 [CM503007]: Call(7): Device joined: sip:techadm@209.212.88.134:5060
    08:40:11.718 [CM503002]: Call(7): Alerting sip:EndCall@127.0.0.1:40600;rinstance=f32573dec7eacca0
    08:40:11.593 [CM503025]: Call(7): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=f32573dec7eacca0]
    08:40:11.546 [CM503005]: Call(7): Forwarding: Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=f32573dec7eacca0]
    08:39:41.796 [CM505001]: Ext.895: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom360/7.1.33] PBX contact: [sip:895@63.224.85.165:5070]
    08:39:41.796 [CM503002]: Call(7): Alerting sip:895@76.109.102.155:5070;line=pjhdyq00
    08:39:41.531 [CM503025]: Call(7): Calling Ext:Ext.895@[Dev:sip:895@76.109.102.155:5070;line=pjhdyq00]
    08:39:41.375 [CM503004]: Call(7): Route 1: Ext:Ext.895@[Dev:sip:895@76.109.102.155:5070;line=pjhdyq00]
    08:39:41.359 [CM503010]: Making route(s) to <sip:895@63.224.85.165:5070>
    08:39:41.359 [CM505003]: Provider:[PINS] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:techadm@63.224.85.165:5070]
    08:39:41.359 [CM503001]: Call(7): Incoming call from anonymous@(Ln.10005@PINS) to <sip:895@63.224.85.165:5070>
    08:39:41.265 [CM503012]: Inbound out-of-office hours rule (Wil Blake direct) for 10005 forwards to DN:895
    CallerID Set Call
    08:41:21.781 [CM503008]: Call(8): Call is terminated
    08:41:08.140 [CM505003]: Provider:[PINS] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:techadm@63.224.85.165:5070]
    08:41:08.140 [CM503002]: Call(8): Alerting sip:techadm@209.212.88.134:5060
    08:41:06.500 [CM503003]: Call(8): Call to sip:895@63.224.85.165:5070 has failed; Cause: 487 Request Terminated; from IP:76.109.102.155:5070
    08:41:06.453 [CM503025]: Call(8): Calling VoIPline:5617033677@(Ln.10005@PINS)@[Dev:sip:techadm@209.212.88.134:5060]
    08:41:06.312 [CM503005]: Call(8): Forwarding: PSTNline:5617033677@(Ln.10000@Patton PSTN Gateway - 0/1 two Conserto lines)@[Dev:sip:10000@10.0.0.189:5070,Dev:sip:10001@10.0.0.189:5072]
    08:41:06.312 [CM503005]: Call(8): Forwarding: VoIPline:5617033677@(Ln.10005@PINS)@[Dev:sip:techadm@209.212.88.134:5060]
    08:40:36.609 [CM505001]: Ext.895: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom360/7.1.33] PBX contact: [sip:895@63.224.85.165:5070]
    08:40:36.609 [CM503002]: Call(8): Alerting sip:895@76.109.102.155:5070;line=pjhdyq00
    08:40:36.281 [CM503025]: Call(8): Calling Ext:Ext.895@[Dev:sip:895@76.109.102.155:5070;line=pjhdyq00]
    08:40:36.171 [CM503004]: Call(8): Route 1: Ext:Ext.895@[Dev:sip:895@76.109.102.155:5070;line=pjhdyq00]
    08:40:36.171 [CM503010]: Making route(s) to <sip:895@63.224.85.165:5070>
    08:40:36.171 [CM505003]: Provider:[PINS] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:techadm@63.224.85.165:5070]
    08:40:36.171 [CM503001]: Call(8): Incoming call from 5619484707@(Ln.10005@PINS) to <sip:895@63.224.85.165:5070>
    08:40:36.078 [CM503012]: Inbound out-of-office hours rule (Wil Blake direct) for 10005 forwards to DN:895
  2. wblake
    Jan 10, 2010
    Calls go through now with an outbound rule for external calls. Previously existing outbound rules only covered extensions.
    -Wil Blake
  3. nashakhalov
    Nov 23, 2009
    10
    Same problems!
    Users have linksys spa922/965
    rule if no answer forward to external 189062602972
    02:13:59.216 [CM503008]: Call(6): Call is terminated
    02:13:54.278 [CM503016]: Call(6): Attempt to reach <sip:226@127.0.0.1:5060> failed. Reason: Not Implemented
    02:13:54.278 [CM503003]: Call(6): Call to sip:189062602972@192.168.0.189:5060 has failed; Cause: 488 Not Acceptable Here; from IP:192.168.0.189:5060
    02:13:54.216 [CM503003]: Call(6): Call to sip:226@192.168.0.200 has failed; Cause: 487 Request Terminated; from IP:192.168.0.77:5060
    02:13:54.216 [CM503025]: Call(6): Calling Unknown:189062602972@(Ln.чччч5@Samsung)@[Dev:sip:10000@192.168.0.189:5060]
    02:13:54.200 [CM503005]: Call(6): Forwarding: Unknown:189062602972@(Ln.чччч5@Samsung)@[Dev:sip:10000@192.168.0.189:5060]
    02:13:44.201 [CM503025]: Call(6): Calling Ext:Ext.226@[Dev:sip:226@192.168.0.77:5060]
