Another DID problem :(
Discussion in '3CX Phone System - General' started by ryan, Sep 5, 2007.
  1. ryan
    Aug 27, 2007
    35
    I have been given a number that has been forwarded with 'delivery set as Sip with RFC DTMF signalling' (quoted from a DID provider).
    I set it up in the DID line, set the DID/DDI number/mask box to the number I see when the number calls in contained within the 'To' field (448458698xxx)
    The security box is set to anywhere and in and out of office hours, the number is pointed at an extension.
    When I call in though, the phone doesn't ring and the logs conain the line:
    [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '87.238.72.xxx'; From: '01242695xxx'; To: '448458698xxx'; Rline: '200'; Contact: '01242695xxx'
    Like I said, the DID mask is set to 448458698xxx. (I have also tried just the last 5 digits of the number)
    Any ideas appreciated!!
    Cheers,
    Ryan
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Try this
    http://www.3cx.com/forums/viewtopic.php?t=2256
    Cheers
    In your case the ip to put there would be 87.238.72.xxx
  3. ryan
    Aug 27, 2007
    35
    Thanks for that - after a nights sleep I saw my error....I didn't put the correct number in!
    Apologies for that - it had been a looooong day :)
