Solved Another Lets Encrypt Certificate failed to renew
Discussion in '3CX Phone System - General' started by THCO, Jul 12, 2017.
  1. THCO
    May 16, 2017
    57
    11
    I received the following email and Im not sure what to do.
    Lets Encrypt SSL certificate was failed to renew. Error: System.AggregateException: One or more errors occurred. ---> PostInstall.LetsEncrypt.LetsEncryptRegistrationException: Lets Encrypt authorization status 'invalid'. Authorization not completed. type : urn:acme:error:connection; detail : DNS problem: NXDOMAIN looking up TXT for _acme-challenge.xxxx.3cx.us; status : 400
    at PostInstall.LetsEncrypt.LetsEncryptClient.<CompleteCertificateGeneration>d__13.MoveNext()
    --- End of inner exception stack trace ---
    at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification)
    at PostInstall.LetsEncrypt.LetsEncryptClient.RegenerateCertificate(CertificateGenerationData certGenerationData, String keyFilePath, String csrFilePath, String domainName)
    at PostInstall.CertificateHelper.ProcessCertificatesDirectory(String directory, CloudServerStatus statuses, String appBin)
    at PostInstall.CertificateHelper.RenewCertificates(String appBin, String nginxConfigFolder, String configurationPath)
    ---> (Inner Exception #0) PostInstall.LetsEncrypt.LetsEncryptRegistrationException: Lets Encrypt authorization status 'invalid'. Authorization not completed. type : urn:acme:error:connection; detail : DNS problem: NXDOMAIN looking up TXT for _acme-challenge.xxxx.3cx.us; status : 400
    at PostInstall.LetsEncrypt.LetsEncryptClient.<CompleteCertificateGeneration>d__13.MoveNext()<---
    How can I check to see if this renewed properly.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,380
    535
    Hello @THCO,
    Please make sure that you can resolve www.letsencrypt.org correctly from the PBX machine and that nothing is blocking the communication between Let's Encrypt and the phone system.
  3. THCO
    May 16, 2017
    57
    11
    This issue has been resolved, received another email the next night stating the cert renewed.
