Answer a call form my phone when another phone is ringing.
Discussion in '3CX Phone System - General' started by Roberto Mammoli, Jun 12, 2008.
  1. Roberto Mammoli
    Feb 24, 2008
    Help!
    My 3cx work very fine, but ...
    ... in the older analog pbx My phone never ring... but if I get a call from my phone when a external line is ringing I press the line botton...and I can answer... with 3cx no??!!
    I want only answer a call from my office, when another is ringing...
    Can Someone Help me?
    thx
    Bob
  2. tigernet
    Apr 10, 2008
    12
    you can use the call pick-up code *20* (commercial editions only) to pick up the call
    Tim
