Answer any extension
Discussion in '3CX Phone System - General' started by giovanni0826, Dec 28, 2007.
  1. giovanni0826
    Apr 6, 2007
    53
    with the new 3cx voip client 5.3724 how do we answer other extensions? i know on v3 it was *10*
  2. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    check the manual of 3cx client in support section it has got all the details you looking for..
