Implemented answering iOS Phone DONE
Discussion in 'Ideas' started by 3CX-IDEAS, Sep 28, 2015.
  1. 3CX-IDEAS
    Sep 28, 2015
    10
    26
    Answer 3cx calls from locked mobile - IN PROGRESS / DONE
    In a corporate environment mobiles connected to Microsoft Exchange are forced to set passwords and lock after a set time interval. It is possible to answer incoming mobile calls from a locked phone without unlocking but it is not possible to answer a incoming 3cx call without unlocking. It would be great to be able to answer the call quicker when the screen is locked!
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    312
    Re: Answer 3cx calls from locked mobile
    This is possible on iOS already
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    Be able to answer the call without unlocking the phone - behave like a normal phone.
    This is probably an Apple restriction - but it is wishful thinking and perhaps Apple has some guidelines on how to work with this restriction and overcome it for specific application types.
  4. Nick Galea
    Jun 6, 2006
    2,007
    312
    This is already done in v14 in latest client on iOS. Before posting ideas, please check the latest versions that the feature is not already there. Otherwise it just becomes impossible to moderate this forum.
  5. craigreilly
    Feb 1, 2012
    3,587
    309
    The link in the welcome email is where I downloaded the iOS app from.
    I see now after flipping thru 1/2 dozen webpages that a new version is pending. But there is no mention of the changes in that iOS App: http://www.3cx.com/blog/releases/service-pack-1-v14/
    Note: perhaps my understand of unlock and your understanding are different.
    I have to enter my PIN to answer a call. I do not do that with a normal phone call.
  6. craigreilly
    Feb 1, 2012
    3,587
    309
    Re: Answer 3cx calls from locked mobile - IN PROGRESS / DONE
    I can not get this to work. Always have to enter my PIN.
  7. Gerald Warren
    Oct 22, 2015
    19
    I have the same issue with iOS. A call ringing the 3CXPhone app on my iPhone when it is locked will not answer without first having the PIN entered or fingerprint read. By that time, the call has usually ended.
  8. craigreilly
    Feb 1, 2012
    3,587
    309
    SP3 - same issue remains. I can not answer the call in time.
    I wish 3cx would re-comment on this.
  9. craigreilly
    Feb 1, 2012
    3,587
    309
    For anyone following - been informed to swipe RIGHT to LEFT on the notification.
  10. blushiftwireless
    May 11, 2016
    I would like to be able to silence a ringing 3cx call on my iphone. Is there a way?
  11. actbig
    Nov 20, 2015
    25
    10
    Take a look there
    mute-incoming-call-function-for-3cxphone-on-android-and-ios-44669.html
    by the way. If a call comes in, the display is still locked and it's not possible to answer the call. Android Version 6.0
  12. craigreilly
    Feb 1, 2012
    3,587
    309
    So swiping the opposite way on iOS allows you to accept or reject call without unlocking the phone.
