Anti-Hacking Module Blacklisting IP already on IP Blacklist
Discussion in '3CX Phone System - General' started by Telcreek, Apr 8, 2017.
  1. Telcreek
    Dec 30, 2016
    27
    Hi. I entered an IP into the blacklist manually at 8am PST and I'm still getting email reports from the system that the Anti-Hacking module is temp blacklisting this same IP all day, 9 hours later. Is this expected behavior?
    10,375
    231
    I would confirm that what you put in, matches what is being reported. Perhaps delete, and re-enter.
  3. agp
    agp 3CX Team
    Aug 19, 2015
    134
    19
    Hi @atakacs ,
    What version of 3CX are you using?
    We are aware of this and some improvements have been made in the latest release to address similar issue.
    p.s: Do you use the default Anti-hacking module settings under Settings -> Security?
  4. agp
    agp 3CX Team
    Aug 19, 2015
    134
    19
    Yes those are the recommended (default) settings. I can't know exactly when the fix will be available but I will keep you posted.
