antihacking email notifications
Discussion in '3CX Phone System - General' started by oliverm, Sep 6, 2011.
  1. oliverm
    Mar 10, 2009
    79
    Is there any way in 3cx to be notified of hacking attempts or failed logon attempts? I can see that there are anti-hacking settings but is there anyway to be notified when this is triggered?
    Failing this is does anyone know if the antihacking process records anything in logs that we could regularly check ?
    Olly
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Management console > Settings > General Settings > Email Notifications.
    These are the email notifications and yes being notified for anti hacking module is available when an IP has been blacklisted.
    plus other options as well.
    Thanks,
    Nate
