Any one tried it out on a Samsung Galaxy III S ?
Discussion in 'Android' started by leejor, Jul 14, 2012.
  1. leejor
    10,861
    302
    It seemed that the Samsung Galaxy III S is being pushed extensively in Europe (and elsewhere) this summer, with kiosks on almost every corner. Just wondering if anyone has tried running 3CX Phone on it?
    It was quite impressive, but not being able to run the App, by years end, would be a deal-breaker for me.
  2. decobezerra
    Jul 18, 2012
    Yes, It works fine.
    But when the 3cx is active it turns the default application to phone call and wont allow me to use the regular phone application, anyone knows how to change that?
  3. Cjay
    Cjay New Member
    Feb 24, 2007
    190
    I guess the tick box "Redirect normal calls (if set, GSM calls are rerouted to use VoIP when possible)" under the integration section of the configuration is supposed to handle the GSM/VoIP choice. Except it doesn't... On my phone this option wont work properly with calls going to VoIP regardless of the setting (plus, if set to force VoIP calls, it seems to deselect itself).
    Apart from that all ok...
  4. leejor
    10,861
    302
    Thanks, I'll add that phone to my consideration list when it comes to upgrade time. Realized after I posted that it's the Galaxy S III, not III S). Of course you can't edit your posts, at this time.
