any SMS MMS integration soon ?
Discussion in 'Ideas' started by sv9080w3u02, Sep 12, 2017.
  1. sv9080w3u02
    Feb 12, 2017
    10
    hello,
    that could be a leverage for 3CX Unified communication system.
    instead of chatting only, that could be great if chat feature can receive/send sms/mms .
    Do you plan to integrate this with any api available like twilio ?
    thank you
