Any Windows Client supporting G729 ?
Discussion in 'Windows' started by vinchu, Jul 11, 2011.
  1. vinchu
    Jul 11, 2011
    any one for this? we need a softphone support G729 ....
    thanks,
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    eyebeam (paid),
    older x-ten
  3. willow
    willow Member
    Mar 1, 2011
    471
    bria xlite,
  4. vinchu
    Jul 11, 2011
    thanks for all your replies...
    I think what I am after is an 3CX windows client to support g729, it is a bit confusing to have the "demo" version of 3cx server with g729 enabled, but they do not supply a client that support g729 codec!
    or did I missed something??
    Cheers,
    Vincent
  5. eagle2
    Apr 27, 2011
    1,085
    11
    G.729 codec is licensed and paid, so you can not get it for free.
    In the commercial editions of 3CX Phone System it is included (number of G.729 licenses equals half of number of SC licenses).
    That's why you don't have it with 3CX softphone, which is free. Try using some of the Counterpath's softphones (paid), which support G.729 if you really need it. 3CX is providing free alternative - the GSM codec for bandwidth sensitive connections.
    Regards
  6. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    iLBC is also supported by 3CX server. Better audio than 729 and free
  7. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    iLBC is great, we are using him for our remote extensions on mobile phone via 2/3g...
