Anybody uses Grandstream GXP 2120?
Discussion in '3CX Phone System - General' started by dotnetfabrik, Mar 10, 2011.
  1. dotnetfabrik
    Feb 24, 2011
    31
    Does anybody use this phone?
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    We do!
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    It shouldnt give you any trouble i believe we have one running around out test network and it works fine.
  4. sigma1
    Nov 20, 2009
    542
    Mark:
    FYI, there were a couple of small bugs but on Software Version: 1.0.1.56 they work perfectly.
  5. voipbaennjer
    Jul 10, 2009
    44
    meanwhile the firmware 1.0.1.66 is released and works fine
