Anyone can success to get the incoming FAX and outgoing FAX
Discussion in '3CX Phone System - General' started by 5qg4, Oct 24, 2007.
  1. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Anyone can success to get the incoming FAX and outgoing FAX by using V4.0.3035.2?
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,005
    308
    We did :) Let me know what VOIP gateway you are using for FAX....
  3. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    if you amplify rx and tx gain on your fxs adapter you can fax also with version 3.
  4. rnoguera
    Oct 25, 2007
    89
    We are succesfully receiving faxes with V4 integrated fax server.
    We can only send from an extension if we use G711 voice codec and fax passthroug. We have not yet succeded in using T.38.
    PSTN Gateway is PATTON 4554.
    In the Gateway, we have created an adittional SIP GATEWAY, all the external calls to the FAX number are routed to this SIP GATEWAY.
    Patton Smartnodes can do this type of thing.
    This way we can tell 3CX that all the calls coming from this particular SIP GATEWAY are fax calls.
    We didn't try the config file generated by 3CX, but we looked at it, and I suspect it was not correct (T38 was not correctlyactivated).
