Anyone having issues with Noobs 1.4.1 on Raspberry Pi SBC?
Discussion in '3CX Phone System - General' started by millennium2, Jun 13, 2015.
  1. millennium2
    Apr 8, 2011
    57
    On all our other 3CX Cloud Tenants, we used Noobs v1.40 for Raspberry Pi for 3CX SBC.
    But our most recent setup for Tenant 8, we use Noobs Version: 1.4.1 (Release date: 2015-05-11) on Raspberry Pi and keep getting these errors:
    "NAT/ALG check:L:80.9[Extn] RESPONSE 200 on 'INVITE' - some of SIP/SDP headers contain inconsistent information or modified by intermediate hop SIP proxy detected:"
    Is anyone getting issues with a SBC Controller running Noobs 1.4.1 for Raspberry Pi?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Re: Anyone having issues with Noobs 1.4.1 on Raspberry Pi SB
    Hi there,
    I doubt the issue is with the Noobs version, what are the IP mentionned after such messages ?
    Are there any SIP ALG / NAT Helper on router/firewall enabled ? If so please disable.
    Also, using voip providers with media server separate from sip server, you might see the said warning with the voip provider IP's, in that case you can disregard this.
