Anyone using a UK ISDN30 VoIP gateway with 3CX?
Discussion in '3CX Phone System - General' started by Pentangle, Dec 9, 2007.
  1. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    I'm looking to install/configure a 3CX system to replace an existing traditional Nortel Meridian PBX served by an ISDN30.
    Q1) is there anyone else out there doing connectivity to an ISDN30 for outbound calls in this forum?
    Q2) if the answer to the above is yes, are you in the UK? and if so - what gateway are you using and can I poach some config screen-captures from you?
    Q3) is the Patton Smartnode 4960 the right device for me? (it *appears* to be, but appearances can be deceptive!). I basically want VoIP inside the office and then ISDN30 for the trunk connectivity.
    My problem is that the 3CX help files detail how to set up a Smartnode 4638 BRI gateway, but not a 4960.
    Finally - I would *LOVE* this forum to include country-specific config details of at least one of each of POTS/BRI/PRI gateways available, so that I don't look like an idiot when I spec up a quote and come to install it and can't.
    Cheers,
    Mike.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Mike,
    ISDN30 should be ISDN/PRI/E1(30B+D) Line. I'm using ISDN/PRI/T1(23B+D). I'm in Hong Kong, the telephone line is using UK standard.
    The Patton SN4960 (Model: SN4960/1E30V/UI) should be works too at UK or somewhere is using ISDN/PRI. Just reminded that the Patton gateway should be not too easy to config.
    You should be know your line is using which type:
    Signaling method: IDAM or IDAP
    Framing: SF or ESF
    Line Coding: B8ZS or AMI
    Error Correction: CRC or BPV
    My ISDN/PRI/T1 is using:
    Signaling method: IDAP
    Framing: ESF
    Line Coding: B8ZS
  3. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Thanks Ricky - glad to see it works well for you (I assume!)
    Cheers,
    Mike.
