anyone using Vista & 3cx client?
Discussion in 'Windows' started by Tugi2o, Jun 26, 2008.
  1. Tugi2o
    Feb 20, 2007
    61
    ist there anyone using 3CX Phone System on Vista OS?
    How does it work => without sound problems?
  2. Thona
    Aug 10, 2007
    54
    The 64 bit issues are for SP1 only, it seems, and Longhorn 64 bit.
    They are fixed - not sure when this goes out to the public, but me and 3cx exchanged some builds that now work fine ;)
