- Joined
- Sep 9, 2017
- Messages
- 36
- Reaction score
- 0
Wanted to know is there anyway to create clone of existing extension with all settings and using same for creating new extension
Yes - use the CSV template.
https://www.3cx.com/docs/bulk-extension-import/
This can be exported from the management interface under extensions.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
