Apache won't start
Discussion in '3CX Phone System - General' started by Anonymous, Sep 20, 2006.
  1. Anonymous
    Anonymous Guest
    Hello
    I have installed the freeware version on w2k3 sp1. all services will start exept apache. This service gives me starting and thats it. When i look in the taskmgr i see the process running. Also with netstat -a it gives me an port that listens. Only the web browsers can not connect. Can somebody help me??
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,992
    308
    Apache not starting
    By any chance, you dont have something else active on that port? Some other software that is using the port?
  3. Anonymous
    Anonymous Guest
    changed apache port
    I have changed the apache port to 8888, but won't help. The problem stays.
    bye
  4. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Thanks for your time and feedback. I am sorry to hear about this odd failure. Can you review the APACHE logs in:
    "C:\Program Files\3CX\PhoneSystem\Bin\Apache\logs"
    and the logs in the Eventlogs:
    Start -> RUN - > eventvwr. (look for entries with source "Apache Service")
    If you wish you can also zip and mail us those logs (support@3cx.com), we would gladly look at them ourselves.
    Thanks once again!
  5. Anonymous
    Anonymous Guest
    Hi again,
    The apache logs are 0kb
    The eventviewer gives me this
    Faulting application 3CXPhoneSystem.exe, version 2.0.0.0, faulting module 3CXPhoneSystem.exe, version 2.0.0.0, fault address 0x0001a800.
    The service says starting.
    My netstat -a says
    TCP server:5481 server.s4f.nl:0 LISTENING
    I shall reboot the machine again and then i report you again.
    bye
  6. Anonymous
    Anonymous Guest
    Hi again
    After reboot the 3cx won't start the eventviewer gives me
    The 3CX PhoneSystem Web Server service hung on starting.
    the apache logs are empty.
    any suggestions (reinstall or something like that)
    bye
  7. Nick Galea
    Jun 6, 2006
    1,992
    308
    Points to a conflict with other software
    These "symptoms" would point to a conflict with some other software. What other software do you have installed that might conflict? Maybe you have some other software installed that also uses Apache for example? Or a previous installation of Apache or LAMP that failed? Any other clues you could give us? We have not received other reports like this, but we are keen to resolve it. If you could send us more details that would be great.
  8. Anonymous
    Anonymous Guest
    Hi again,
    I have found the time to install it on another machine and that works correctly. I going to test the APP on that machine.
    Thanks for the support..
