API and answering a call
Discussion in '3CX Phone System - General' started by simonatkins, Jul 8, 2014.
  1. simonatkins
    Nov 2, 2011
    9
    Is it possible to answer a call which is ringing an extension using the API?
    rgds
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Yes you can achieve lot of things through API.
    Please refer to the CHM documentation for v12 API available on : http://www.3cx.com/downloads/misc/callcontrolapi/3CXCallControlAPI_v12.zip
