API as windows service
Discussion in '3CX Phone System - General' started by asmith3006, Sep 21, 2016.
  1. asmith3006
    Mar 5, 2014
    94
    5
    Has anyone successfully built V15 API into a Windows Service?
    We're running it as a WinForms application and this works fine, but running as a Windows service gives
    Code:
    Unable to load DLL 'tcxpscom_native': The specified module could not be found. (Exception from HRESULT: 0x8007007E)    at TCX.Configuration.PhoneSystem.RegisterListener(MyPFN_UPDATE_LISTENER f)
       at TCX.Configuration.PhoneSystem.get_Root()
    Any input would be greatly appreciated
    Thank you
  2. asmith3006
    Mar 5, 2014
    94
    5
    For anyone else who has this issue:
    When you build the service VS includes the DLL for some reason (even if set to exclude). Once you install your service if you manually delete the DLL from the installation directory (NOT the Program files\3cx\instanceX directory) then the service locates the real DLL and it all works fine.
  3. Hardik Soni
    May 22, 2017
    19
    same error occured while to get PhoneSystem.Root.GetDN()
