API commands for version 7 not working
Discussion in '3CX Phone System - General' started by russellcrowe, Jan 7, 2009.
  1. russellcrowe
    Nov 18, 2007
    31
    we have upgrade to version 7
    this is new code we have tried for make call from external app
    http://192.168.10.12:5484/PbxAPI.aspx?func=make_call&from=144>&pin=144&to=907710608222
    we used to use this code in version 5 and it worked
    http://192.168.10.12:5481/make_call.php?extnum=144&vmpin=144&to=901616605738
    any ideas on what we are doing wrong
    thanks
    russell
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,439
    61
    Hi, Russell
    If links you quoted here are those you used, then the one you said is not not working is mispelled - there is a ">" after "from=144". Remove it and try this first.
    vali
    P.S. Ok, if there was a "first", then let's disclose the "second" also 8) You don't specified here the PBX webserver running on 192.168.10.12. If is an IIS 5.1 running on XP, then try the following link:
    http://192.168.10.12/IVR/PbxAPI.aspx?func=make_call&from=144&pin=144&to=907710608222
    P.P.S Alway be careful that these links are case-sensitive, as for most webservers. Therefore, the MAKE_CALL& or pbxAPI or ivr will make your links incorrect.
