API for call status (not control)
Discussion in 'CRM / Helpdesk / App Integration' started by imseanbrown, Dec 26, 2017.
Tags:
  1. imseanbrown
    Apr 17, 2017
    7
    Hello --
    Would like to see if there is documentation for getting status for certain objects via API...
    Number of agents logged in to Q
    Number of agents available (or busy) in Q
    Number of services calls in Q
    Number of abandoned calls in Q
    Average hold time in Q
    Number of active calls (system wide)
    Number of registered extensions (system wide)
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,598
    125
