API Login Failing on v11
Discussion in '3CX Phone System - General' started by lemuppet, Aug 22, 2012.
  1. lemuppet
    Mar 23, 2010
    24
    Hello
    I have an application that was written against v10 of 3CX. I have now installed v11 on our server and can no longer get the API to connect. I have tried using the new DLLs (sl and 3xcpcomcpp2), tried compiling in c# 4.0 and have had no success.
    I get the error "Config server is not connected" when we try to run the command:
    ps = PhoneSystem.Root;
    Does anyone have any ideas please?
    Thanks in advance
    Steve
  2. Fooxtalt
    Aug 20, 2012
    Turbin
    I apologise, but, in my opinion, you are mistaken. I can prove it. Write to me in PM.
