API question version 7 with IIS
Discussion in '3CX Phone System - General' started by ansu2723, Jan 29, 2009.
  1. ansu2723
    Nov 23, 2008
    29
    Is it possible to set my status to Available or Away?
    And is it possible to set queue status to logged in or logged out?
    If not
    Is it possible to change these settings in the database?
    Happy for a fast answer.
    Im setting up a fingerprint scanner that will be uses to log people in and out from the office.
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    HTTP API calls as per your request are currently not available.
    The commands available can be found at http://wiki.3cx.com/Home/api/http-api .
  3. ansu2723
    Nov 23, 2008
    29
    Is it possible in the other API?
    Is there any documentation for that.
    If that is the case I can write a program that runs on my 3cx server.
